Clutch Help
Old Jun 18, 2008 | 05:59 PM
newb2000GT's Avatar
newb2000GT
Default Clutch Help
So my clutch started making noise today. 40k miles on a King Cobra cluthc. When I touch the pedal it makes a slight squealing noise and changes pitch about midway through the range and then stops at full depress. It makes sort of a whirring noise when fully depressed. When let out completely there is no noise and the car transfers power just fine with no slipping. I stopped at my mechanic friend's house but he was not home. Once I leave there it did it one time and the noise went away. WTF?
Any ideas? Is this a throw out bearing going bad? I had everything replaced when it was installed and I've never had clutch problems in any car so this is new to me.
TIA for the help.
Old Jun 18, 2008 | 07:00 PM
bryan0's Avatar
bryan0
Default RE: Clutch Help
Sounds like a throwout bearing noise. But usually when the clutch is fully released is when the noise is the loudest. Keep an eye on it, if it gets worse and more distinct it's most likely the TOB. If it is, you've still got a few thousand miles at least before it really needs to be changed.
Thunderball
15
Nov 22, 2015 11:49 PM
junior04
Sep 28, 2015 10:53 AM
MacSerio
Sep 27, 2015 01:05 PM
ccdguy
Sep 19, 2015 05:20 PM
MasterLanMan
Sep 13, 2015 08:21 PM
