what 2 do next?
what 2 do next?
sup guy i think my piston rings r going bad cause i c a little blue smoke from my tale pipe and that rarly happens so i was woundering should i just get a stroker kit or just replace the rings and by the way im stayin n/a
RE: what 2 do next?
well if you plan on keeping it for a while might as well pull it out and do the entire long block over. Unless it is just the heads. i would pull it out and do the heads and rotating assembly, def. stroke it
RE: what 2 do next?
rebuild it probably would cost around $500 not including honeing and prep of the block.
head gaskets
jackingbolts
head bolts
main bearings
rod bearing
piston ring set
FORGED IT.........or do what im going to do later.............Billet it!!!
head gaskets
jackingbolts
head bolts
main bearings
rod bearing
piston ring set
RE: what 2 do next?
were can i go to do that and is it cheap? [bulliet mod ]
ORIGINAL: redstanger
head gaskets
jacking bolts
head bolts
main bearings
rod bearing
piston ring set
head gaskets
jacking bolts
head bolts
main bearings
rod bearing
piston ring set
