Removing Mach 460 amps?
Old 07-01-2008 | 07:27 PM
ZW99GT's Avatar
ZW99GT
Default Removing Mach 460 amps?
I know almost nothing about stereo stuff. I'm putting the car on a slight diet. Nothing crazy, still full interior and such.
I hardly ever listen to the radio as it is. Can I take out the amps/rack in the trunk, and still have a working stereo?
Old 07-01-2008 | 08:02 PM
grogan's Avatar
grogan
Default RE: Removing Mach 460 amps?
if its the mach 1000 (comes with the amps and subs) then i think when u disconnect the amps from the truck i think only the front speakers will work i think the back speakers and subs are powered by the amps.
Old 07-01-2008 | 10:21 PM
BraMas's Avatar
BraMas
You should be fine the front speakers are powered by the amp under the radio. To test it fold your rear seats down and look up at the box and you will see where the harness plugs into the amps. Just unplug them and make sure everything still works. FYI you can unplug the harness that powers the rear box that way you can sell the box with the harness if you wanted
Old 07-01-2008 | 10:28 PM
mvr's Avatar
mvr
i have aftermarket deck and speakers and have basically removed the mach stuff. if you take the rear amp rack out comepletely you will only have the front tweeters working as they are powered by the headunit. also to remove it you have to take the carpet on the rear deck off to get to the screws. then i removed the amps from the racks to unplug them from the wireing. any questions pm me as i just did this a few months ago.
Old 07-01-2008 | 10:48 PM
ZW99GT's Avatar
ZW99GT
ORIGINAL: mvr
So my door speakers aren't even gonna work? I have to have a stereo. More than just tweeters. I'll go unplug them and see if I like what I hear. I'm not too picky about it, but it's gotta be fairly loud to be heard over the turndowns. lol
Old 07-02-2008 | 12:25 AM
Sxynerd's Avatar
Sxynerd
I'll put it this way, taking out your factory amp is easy if you have an aftermarket deck. If you do the new problem will be that the MACH system work on a 2ohm load and aftermarket decks work on 4ohm. So basically, you'll need aftermarket speakers and to run new wires. I do it all the time and in a mustang takes me about an hour.
the stock head unit is mediocre at best.... a 79$ JVC is even better.
Old 07-02-2008 | 12:39 AM
califas_1987's Avatar
califas_1987
i was under the impression that the mach 1000 amps in the back were soley used to power the 2 subs. 2 amps per woofer (they are dual voice coil; 1 for each coil), and the amps in the side panels and under the dash were to power the other speakers.
Old 07-02-2008 | 01:04 AM
ZW99GT's Avatar
ZW99GT
Ok, first off I don't have the Mach 1000. I have the Mach 460. There are 2 amps in the trunk. There's no subs in my car. I don't want to replace them. I want to throw them out to save weight.
Old 07-02-2008 | 01:15 AM
BraMas's Avatar
BraMas
Technicaly the bigger speakers in the box are Subs. Thats why everyone says that. Just do what I said unplug the box and see if you like it
Old 07-02-2008 | 01:28 AM
Sxynerd's Avatar
Sxynerd
What I said is gods word... You'll save around 25-30 pounds by rewiring an aftermarket system.
