here is a link to the full length ones. I would probablly get these but you could save a little $ and get the un-powdercoated ones but thay wont look as good.
Yup, remove the carpet unless you want it to catch fire. Plus make sure the shop that welds the connectors in does it on a drive-on lift. The suspension has to loaded in order for the connectors to be installed correctly.
this is true the suspension should be loaded while welding them but you shouldnt need to remove nay carpet.... unless of corse you have carpet under your car. these get welded under the car not inside the interior.
