4.6 EGR Delete Plate
So i bought some new Pypes Long Tube headers and the part on the header (driver side)that connects to the EGR pipe didnt have a Male end on it and when i called them and asked where the part was they said they dont supply that part. So they said to get this...
http://www.uprproducts.com/shopping/shopexd.asp?id=806
Should i just get this? Would it be bad to delete this pipe..? If i did delete it would i not be able to pass inspection??
any info on this product would be nice
tahnks guys
tahnks guys
RE: 4.6 EGR Delete Plate
The EGR reduces the NOx released into the air. It also is used to take up space in the combustion chamber so you can use less of an a/f mixture worsening performance. If you just delete the EGR with out a retune then your car will not run right in off idle driving, it doesn't effect it on a cold motor or at WOT.
I guess i am just going to find the adapter to connect the egr to the headers then.. id just feel better if i kept it.
Does anyone know where i can get the adapter piece to connect the two??
