what is this
RE: what is this
i have the same damn thing. I cant figure ou where its coming from and its not an exahust leak cause it wouldnt be a constant hissing it would be like a pulse of hisses. I have the exact same symptoms as you though if i rev it a little it gets louder but after the car warms up it slowly goes away but it happens everytime i start it. Tell me if you find out the solution cause its pissing me off.
RE: what is this
ORIGINAL: cassimus
well i thought i had an exhaust leak but come to find out its something on top of my motor on the driver's side. a guy at the exhaust shop said it could be my pcv valve but what do you think?
[IMG]local://upfiles/58050/005AC74A3A494CDFB0AF0CA8B3D31E39.jpg[/IMG]
RE: what is this
ORIGINAL: 029s
Your EGR valve is the black round thing attached beside your throttle body. It has a wire coming out of the top. Don't know if that is your problem but it is close to the area you are hearing the problem.
RE: what is this
its that rubber hose that connects the tube to the intake.they get old and need to be replaced i actually had a peice of i think heater hose that i cut to fit when mine did that.what youre hearing is the intake sucking air from that tube and the reason theres oil there is because the newer cars all run a closed loop setup for the pcv's.replace that rubber hose and it should cure it
RE: what is this
funny i found it but it doesnt make any sense it was the spark plug boot on the driver side 3rd one back from the front i can move it more vertical under the fuel rail and it almost dissappears instantly and it comes back when i move the boot more towards the valve cover i dont know anymore im stumped
