Check Engine Help... PLEASE!!
Old Jul 30, 2008 | 04:28 PM
96GTMustangCT's Avatar
96GTMustangCT
Default RE: Check Engine Help... PLEASE!!
Just got back from Advanced Auto and i used the tuner to check what codes are being thrown. I got P0156 and then the second code was the same P1056. The second one said bank 2 sensor 2 pending. Idk wtf that means. So now my question is, do i clean the rear o2s to see if they still work, get new ones?? hopefully this is an easy fix and my steeda mils are still in working order.
Old Jul 30, 2008 | 07:24 PM
96GTMustangCT
anybody?
Old Jul 30, 2008 | 07:42 PM
blackstallion666's Avatar
blackstallion666
P0156 - HO2S Sensor Circuit Malfunction (HO2S-22) which is the driver side rear o2 sensor.
These are the possible cuases given from my service manual.
[*]Pinched, shorted, and corroded wiring and pins.[*]Crossed sensor wires.[*]Exhaust leaks.[*]Contaminated or damaged sensor.[/ul]
If i were you and you crawl under there and check the connector and wiring and don't see anything damaged. I would throw a new down stream o2 on it for the driver side. It you want to be possitive if its bad try swapping it for the one next to it. Clear the codes by disconnecting the battery for atleast 5 minutes. And take it back to see if you get the same code. If you get acode for the passenger side this time you know its the sensor and your wiring is good.
Old Jul 30, 2008 | 08:18 PM
96GTMustangCT
what do you mean crossed wires? like mixing up the left and rights?? so ima go buy a new o2 for the left and see what happens
Old Jul 30, 2008 | 08:20 PM
blackstallion666
yea they mean crossed connectors
Old Jul 30, 2008 | 08:26 PM
96GTMustangCT
so first i will switch the left and right rear o2s, then try buying new ones. then ill see from there? sounds like a good plan??
Old Jul 30, 2008 | 08:38 PM
blackstallion666
yea just swap the rear o2's positions put the right one on the left side and vise versa. If you get the same code you now know you have a problem with the wiring for the sensor on the driver side rear o2. Now if the code comes up for the passenger side rear o2 you deffinatly know the o2 is at fualt.
Old Jul 31, 2008 | 06:19 PM
96GTMustangCT
so i just got done and switched the left and right rear o2 sensor vise versa and noticed that the right one had a loose wire where i had installed the set of mils that i made the first time. I had to splice and crimp the wire.. blah blah blah so that is where it must have come lose. So i just fixed that and i turned the car on, drove it home about 10 miles away from my buddies house and the CEL is still on. Will it reset itself? should i clear it? or hopefully someone has the answers cuz idk what it could be. Thanks guys.
Old Jul 31, 2008 | 06:20 PM
blackstallion666
Your gonna have to clear it again.
Old Jul 31, 2008 | 06:50 PM
96GTMustangCT
yah thats what ill do tmrw then. so im thinkin when i just checked the codes yesterday, banks 1 and 2 for the rears came up because the one o2 wire was all f'ed up and then the other one threw a code maybe because it was crossed/ in the wrong side. i will clear it and hope and pray. ill keep you updated and thank you so much again for all your help man.
djbigskrilla
Sep 20, 2022 01:04 AM
J.casone400
Aug 28, 2015 09:33 PM
labudski
Aug 24, 2015 07:23 AM
microgt
Aug 20, 2015 07:12 AM
mweiland
Aug 13, 2015 05:11 PM
