Engine squeak...please help!
Old Jul 30, 2008 | 11:52 AM
gt_stang101's Avatar
gt_stang101
Default Engine squeak...please help!
Hi guys, haven't been here in a while.
The engine belt area is making a squeaking sound... and I've tried everything to fix it. The belt and pulleys probably have maybe 5,000 miles on them first off. The belt is in great condition. The noise seemed to be coming from the idler pulley, so I took it off and soaked it in chain saw oil for about an hour trying to relubricate it, but that didn't work. So then I figured it may be the idle tensioner spring, so I took that off and lubricated that with some rem oil and that didn't work, but the noise seems to be coming from one of those two things. Like I said the idler pulley is new, so do I need a new idle tensioner?
Taking the stang on a 300 mile trip tomorrow and don't feel like listening to a squeaky noise for that long...
Thanks for any help.
Old Jul 30, 2008 | 02:14 PM
jwarner0297's Avatar
jwarner0297
Default RE: Engine squeak...please help!
I would take the belt off completely and run the motor to see if it still makes the sound, if so neither of those things is your problem. Just do it when your motor is cool cause you won't have the water pump working.
If it still does it my 2002 was the same way and it was my syncronizer which is at the front of the engine, ended up being a $185 for the part.
Old Jul 30, 2008 | 04:41 PM
98redstang's Avatar
98redstang
+1 dont let it got hot or you screwed
Old Aug 4, 2008 | 03:43 PM
gt_stang101
Ok guys I drove it down there squeaking and now it's parked till I get it fixed. I just took the belt off and no squeaking whatsoever. But I have a question, what are you calling a syncronizer? Have a pic?
So I've pretty sure it has to be a pulley... But I soaked all of them in chain saw oil so that should have eliminated all squeaking?
Please help!
Old Aug 4, 2008 | 03:50 PM
devineju's Avatar
devineju
I would be willing to bet that it's the idler pulley. Mine was squeking real loud while being parked. As soon as I took the pulley off, the bearings fell out. The oil will not fix a pulley with bad bearings.
Old Aug 4, 2008 | 07:36 PM
gt_stang101
Ok, I just replaced the idle tensioner pulley and the sound got worse... It fixed the squeaking, but now it makes a worse sound, kind of like a grinding sound. I checked the belt and it's fine, checked the tensioner and everything is fine. I have no clue what is going on...
Old Aug 4, 2008 | 08:40 PM
phorr20's Avatar
phorr20
When does it make the squeak?
Mine seems to squeak when I'm on the gas and at high RPM'S.
Thx
Old Aug 4, 2008 | 09:22 PM
gt_stang101
Not really a squeak anymore, more like a grinding noise. Makes it all the time, idle/high rpms.
Nick Oliver
Oct 17, 2018 04:22 AM
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
rksnow1
Sep 14, 2015 08:46 PM
TfcCDR
Sep 14, 2015 12:08 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
