will it blow my engine?
I'm pretty sure i'm gonna be gettin a vortech v-1 s trim non- intercooled supercharger kit on my 01 mustang GT. The only thing making me hesitate is that i only have a few bolt on engine mods so i'm not too sure i won't blow my motor even at 8 psi. Will i blow it up if i don't add any major mods?
RE: will it blow my engine?
Everything I've read says to keep the boost to 6-8 psi if you do not have an intercooler. That should get you 340-350 rwhp but you will need a good tune to prevent detonation.
P.S. How high you can go depends upon the other supporting mods that you have. I'm not sure I would try to get to 400 rwhp with a non-intercooled supercharger. I also wouldn't go above 400 using boost alone. If your car is a daily driver, every tuner I've talked to has said to stay around the 370-380 rwhp range.
There are no gaurantees. Engines have blown up on the dyno at 350 rwhp.
