Timing
My 96 2v was taken apart by somebody else. The cam was out of the one head and the crank was turned while the heads were off. The marks on the chains are worn off and I have no idea how to set the timing right.
Can anyone give me some advice?
ORIGINAL: n0th1n2kn0vv
Can anybody help me out? I can't seem to find anything about it in the manual.
https://mustangforums.com/m_3081129/tm.htm
And you can thank the Ox man for that sticky.
ORIGINAL: 96GT226410
Try here:
You don't want to turn the crank at all. Move the cams to put the chain on. Make sure each chain is mark by folding the chain and marking the exact opposite ends links. Then with the crank at 9 put both of the chains on, with the guides in place (no tensioner) and being careful line the middle of both mark links with the cam key and the crank key.
I put cams in mine a few weeks back and had a few ptv problems meaning I had to take take the cover off a total of about 5 times and set the timing and make adjustments MANY times. Here is the easiest way I can tell you...
1. Find TDC. The keyway at X oclock seemed to be bs for me. Different books,websites,write ups all said different stuff and none seemed to be correct. Put the front cover on and hold i it on by a few bolts which dont have to be torqued or anything, put the crank pulley on and turn it until the crank pulley mark lines up with the tdc mark. Other way to do it is with a tdc stop and degree wheel
2. Fold the chains in half, using an automatic punch, nail polish etc mark the end links
3. line up one mark on the mark on the crank, line up the mark on the other end with the marks/dots on your crank gear
do this for both sides and youre good to go
