Rear end lubrication
Old Aug 14, 2008 | 05:55 PM
Redfire UFO's Avatar
Redfire UFO
Default Rear end lubrication
ok so i have a 02 gt 5spd..... it has 70k on it now, and i notice that every once in a while when i take a ride turn hard.... only that wheel spins........ so i guess the friction modifier for the limited split discs is worn out.... what fluid do i need to put in it so they will grab again.... i was thinking the royal purple, but does that have the necessary friction modifier additive that i need?
Old Aug 14, 2008 | 06:02 PM
GhostRider02GT's Avatar
GhostRider02GT
I used to do RP and the friction modifier. Back when I used to use it, now im too lazy and just do the RP, seems like everything back there is fine. got 67K miles
Old Aug 14, 2008 | 06:32 PM
Redfire UFO
thanks.... if i add the extra friction modifier will that help me out on my one wheel peel situation
Old Aug 16, 2008 | 08:56 AM
cliffyk's Avatar
cliffyk
TECH SAVANT
No!
Friction modifier makes the oil more slippery so that the clutch plates do not bind--adding more will make it slip more...
"Back in the day" a cheap trick for the strip was to use less friction modifier (or even none on a trailered racer) to get more lock-up. With none, on the street, the clutch packs will pop and creak and make a general racket.
Old Aug 16, 2008 | 09:06 AM
Jbauer's Avatar
Jbauer
Royal purple has its own additives for the Posi, and so does the Redline I use; But everyone i spoke to told me to add the Ford friction modifier..seems to be doing well
Old Aug 16, 2008 | 09:13 AM
cliffyk's Avatar
cliffyk
TECH SAVANT
You don't need FM with any synthetic gear oil--not really because it already "has it", but because the synthetic oil in inherently "slipperier" then dino oil.
Adding FM to synthetic gear oil will further lessen the clutch packs' ability to lock up.
Old Aug 16, 2008 | 04:05 PM
OUTLAW1969's Avatar
OUTLAW1969
Agreed, and well stated CliffyK .
Old Aug 16, 2008 | 04:27 PM
tspoon965's Avatar
tspoon965
So it appears there is an issue with the clutch packs, not necessarily with the friction modifier.
Old Aug 16, 2008 | 04:32 PM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
I agree...
Most likely, fluid isnt the issue. These 8.8s take a lot of abuse, and people seem to forget about the clutch packs back there. I know my car needs a rebuild... I bet thats what your rear could use. I've even heard of people adding extra discs in there to make it lock up better, but driveability may be hindered..
Old Aug 16, 2008 | 04:44 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
Unless some misguided soul loaded the rear-end with synthetic oil and FM, and then more FM 'cause they had an ***-end to understanding of which way friction modifier modifies friction...
If so and I knew the LSD had not been abused, or had a ton of miles, then I'd drain whatever is in there out, fill the pumpkin with straight 75W-140 dino juice (no FM), and drive it for a bit.
This is a bit of a kludgy/sleazy "fix", however the friction plates may be so loaded with FM and synthetic oil that they will "dry out" and start to do what they are supposed to do--and if they start to bind (you will know it if they do) you could throw in a couple ounces of FM...
mtgldr
Feb 3, 2024 09:00 PM
zsmart
Convertible Tech
Feb 29, 2016 08:33 AM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
fastbackford351
Sep 12, 2015 09:42 AM
Dragonus18
Sep 9, 2015 01:21 AM
