Missing again.
Old 08-15-2008, 12:29 AM
99gt302
99gt302's Avatar
Default Missing again.
Well my car started missing again. 99 GT, 4:10s, XPipe w/ no cats, flow masters, mac cai.
I replaced coils with some used ones(all tested good on OHM test) I think its got a bad one again, when its humid out it does it most. Before I start checking coils, is there anything else it could be? IM not throwing a code for misfire. I know u can check the COPS with an ohm meter(all read 5.7X and up) can I ceck any other part of the ignition to see what it could be? Seems to do it mostly in lower RPMS/High Gear. I replaced the fuel filter also.
Also, I have been running ngk tr6s since I use nitrous but I believe they may be too cold. I blow a lot of black smoke and run pretty rich. Would a hotter plug help burn off the fuel more?
99gt302 is offline
Old 08-16-2008, 09:10 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
"Blowing black smoke" and running "pretty rich" will cause misfires. Also, how many miles on the plugs?
The NGK TR6 is just a plain ol' cheap conventional electrode plug, if they've got over 15k on them I'd replace 'em just for good measure. A hotter plug would help too if you can't fix the overrich condition...
cliffyk is offline
Old 08-16-2008, 10:20 AM
99 GT vert
99 GT vert's Avatar
i have the same problem and i cannot figure it out either i have tried changing the coils but no luck yet
99 GT vert is offline
alan0614
Carolina Regional Chapter
38
11-30-2015 09:24 AM
Matt's 95 Stang
10-05-2015 07:16 AM
Dathan
10-05-2015 05:52 AM
breaking
10-02-2015 01:27 PM
Quick Reply: Missing again.
