yah i was thinking about getting the ford b springs but they only a 1inch drop idk if that will take it out for 4x4 stance ?
yeah the drop isn't as much as other springs out there, but if you take out the isolators and wrap the coil with electrical tape then that should give you a bigger drop.
umm yea thats the science behind it linear progress ? spring rates ? dropped ??
The roush springs are progressive although they do not say their rate. The Stock fox springs are linear spring but have a lower compression rate which launches better. It is also lowers the rear from .5-1"
