running rich....help
ok my car is runnin rich and its gettin way worse...i have the air/fuel ratio gauge and its completely over in the rich side at times and then sumtimes a lil or none at all and idk wat to do...i have papers that say its been dyno tuned and blah but i also have a handheld tuner and it only adjusts wot fuel and its runnin rich on idle and it sputters a little and it has a slight hesitation and more power at times then at other times...ne help is needed and welcome and also how bad can this hurt my car thnx
yes they certainly can. the vaccum pulls air while your at idle, actually it pulls air in constantly but it does more work at idle, so if there isn't as much air being sucked in, it could run rich. If ur gage says that you are running rich at more than idle, i would def. say its a sensor. the O2 sensor measures the exhaust gasses and sends that info to the pcm to determine how much fuel to dump in. I would take it to a shop and let them have a look at it, they can determine what is going on.
If you have a vacum leak it would cause the engine to shake and sputter at idle and would create a lean condition. The O2 sensors would see that and the computer will over correct causeing it to run rich as hell to keep the engine safe.
the only thing the rear o2's do is monitor the cats. And don't affect the running of the engine. Take a look over all your vacuum lines. Make the intake tube is tight etc. and take it from there.
