car shakes and boggs
ok my sisters car which is an auto 03 mach 1 with just a catback and an intake spacer just randomly started to shake a lot when cruising when you give it some gas. Sometimes even from a dead stop when you give it gas you can feel it shake before it moves. I just replaced the plugs and it didnt help at all. There are no cel codes either. Any ideas, car has 33k miles and was driven like a 90 year old woman owned it lol
my car used to do this... plugs didn't help either, once i did plug wires all better..no more miss. But33k miles hmm idk could be plug wires i guess... did this happen recently after the catback or intake spacer was installed?
car has had mods since 10k miles, her car has cop's
I would try cleaning the EGR valve my car was actually doing this just the other day but threw a code so i took it to autozone for the free checkup. Use some carb cleaner to clean it out, after i did this it ran a lot better it was bogging down to a point where you had to go half way or more with the petal. Car is still running rich so taking it to the shop to get a real diagnostic, but try that and see if it helps at all.
my car was doing the same exact thing. finally threw a code. misfire in #2. switched the #2 with #1 coil to see if id get mis fire #1. bc if i did then i kno its the coil. but hasnt acted up since i switched them,
92 5.0stang
Aug 13, 2015 06:46 AM
Milan Dragway
Aug 12, 2015 03:43 PM
