How do you install a Strut tower bar?
I might be getting a BBK strut tower bar, how do you install the thing? I know it's supposed to hit the strut towers on both sides but.. there's no holes.. lol
so can it just sit there like normally on the ground for the weight of the vehicle to be on its struts. i ask because i have one that i was wanting to put on after i get my engine running correctly.
Realistically, it doesn't matter all that much:
A) Once you loosen the strut mount nuts, the struts can/will move in/out, so minimizing that movement is key to prevent the need of getting another alignment
B) You're still going to have to do a little finagling to make sure all of the bracket points line up..
C) The instructions may give you a sort of "secret," as to how to install with the minimal collateral affect..
I did mine without raising the car, but my Camber was almost maxed out (OE) with the lowering springs I had, so it was easy to just pry the entire mount over to "Zero."
JT
JT
The newer cars, like my 2003 vert, do not have the holes so you have to drill.
I installed the MM STB and while not rocket science it IS a PITA.
For that model you have to drill A LOT of holes.
Make sure you have very sharp drill bits and a good powerful drill.
Make sure the car is on the ground and LEVEL side to side.
Lay the bar on and position it so that it is centered, mark the holes and drill away.
