bogging sputtering.....
Old Sep 3, 2008 | 06:28 PM
armyhowe123's Avatar
armyhowe123
Default bogging sputtering.....
ok i have a 2001 gt stock as far as i know besides exhaust. anyhow when i hold the pedal down between 30-45 and keep throttle steady it'll bog like it isnt getting oxygen or gas. and it occasionally will die when i roll up to a stop light. Any ideas or for sure answers to what this could be from?? fuel filter going bad? o2? please let me know
Old Sep 3, 2008 | 06:32 PM
SVTfan4life's Avatar
SVTfan4life
check your air filter, then look at the coil packs and spark plugs. You wash the engine bay recently? Bc then that could be a major culprit. Also changing out the fuel filter and air filter and putting in some fuel injector cleaner will help too. Mine was doin the same exact thing, so i dried out my coil packs, changed my plugs (MOTORCRAFT only!!) and it drives lke a dream now.. just my .02
Old Sep 3, 2008 | 06:37 PM
armyhowe123
how do u dry out the coil packs im not a big car mechanic but im trying t oget into it and get better in this topic
Old Sep 3, 2008 | 06:59 PM
armyhowe123
any1 else with input help please
Old Sep 3, 2008 | 08:19 PM
blackstallion666's Avatar
blackstallion666
kinda sounds like you have a sticking egr valve. you can plug the off the vacuum going to the egr to eliminate it from your diagnosis. And go for a drive and see how it runs.
Old Sep 3, 2008 | 08:53 PM
russ98stang's Avatar
russ98stang
i was thinking the egr also. my does it at low rpms though. but he also said its at 30 to 45, if it was egr, wouldnt it happen in every gear at that rpm range?
Old Sep 3, 2008 | 09:42 PM
blackstallion666
not always. Since the egr is comanded on under cruise conditions. aprox 35 + and light steady throttle. You may not always notice it at the same rpm.
Old Sep 3, 2008 | 10:08 PM
russ98stang
i get really bad misfire or some jumping **** at about 1100-1400 in 1st but when i unpllug the dpfe thing and the other egr sensor thing it quits
Old Sep 3, 2008 | 10:24 PM
SVTfan4life
get a new one for like 40 bucks and call it a day. or clean it out using electrical parts cleaner, and some thin pipe-cleaner....
Old Sep 4, 2008 | 06:43 AM
armyhowe123
so i need to replace the egr valve and try that?
