cleaning injecters... posted in other 4.6 section but nor esponse...
So tomorrow i think im going to manually clean my injectors, any suggestions as to anything i could soak them/ clean them out with?
i would use carb cleaner or tb cleaner.. anything safe enough to spray into your TB while the car is running is good enough to use on the injectors.
EDIT: while ur at it check the o-rings, just to be safe..
if u want to do it without even pulling the injectors.. just get a sealed valved canister and hose(i cant think of what the name is for it). hook it up to your shrator valve pull the fuel pump fuse and run fuel injector cleaner through it. its what the dealerships do when they clean ur injectors
09-25-2015 06:58 PM
09-25-2015 06:42 PM
