yeah thats the new Trick Flow Intake, I also see caster chamber plates too. I want to get that intake maifold but I dont know if my shaker hood will work with it.
the alternator has a new bracket and the alternator is turned around backwards. also the cold air intake pipe attached to the throttle body is different.
"the alternator has a new bracket and the alternator is turned around backwards. also the cold air intake pipe attached to the throttle body is different."
both of those are a part of the Trickflow intake manifold kit.
The trick flow requires the alternator to be mounted backwards. And the bracket comes with the intake, fyi.
You're wrong sorry, There is nothing in common with the SVO intake except the look of the intake coming across the top side. Totally different designed runners and flows more than 30% better.
