Coolant temp gauge not working
Ever since I went to the track last Thursday, Afterwards I realized that when I start my car for the first time of the day, the coolant gauge does not work at all. After I drive for like 10 minutes, the needle eventually shoots up to around the middle where it usually is.
Has anyone else experienced such a problem or know the fix?
Thanks,
Brandon
Thanks,
Brandon
In a 2004 that's not good. 99+ has only one temp sensor for the ecu & gauge as they share the duty. If you haven't noticed your car running in loop, keep your eye on it and try and either get a new sensor or find the short.
What doyou mean by running in loop? Basically when I start my car for the first time of the day then the coolant gauge is like dead. After a while of driving, it slowly creeps up to the normal place which usually around the middle.
I'm not sure whether or not it is normal. I am pretty sure in the past once I start my car even for the first time of the day, the coolant gauge will start shooting up, it just takes some time to get to the middle area, but it does start shooting up right away and not look dead.
i could tell cus when i go to work in my car, i park up and a couple hours later my temp gauge is a little under half, meaning the car was cooling down.
i don't know if the OP has gone to the store for a couple of hours, then returned to his mustang seeing that his temp needle isn't all the way down, if he hasn't i suggest he does this. only way you can make sure it works without actually doing anything.
