When I had Ford do my tune up I told them that I need a colder plug so I could use my nitrous. Is there a way I can tell if they put the right one's in. I'm going to fill my bottle tomarrow and I want to test it out for the first time!!! Any help would be appricated thanks.
Yea. Pull one out. Check the number and verify it. How big a shot? Just make sure you can pull some timing when you hit the bottle. I would highly suggest you have a tune built for the nitrous using an X-cal or a Diablo. 2 degrees per 50 is about average.
This is the spark plug that I have. Motorcraft AGSF 22WM (8B), this is all the info on the plug if someone can tell me if this is ok to run with my 75 shot? Thank you.
Let me know how it goes RAZER. Next month I will be installing a ZEX nitrous system. I was thinking about running a 100 shot. Do you think that is a bit to much?
You will be ok with that plug and a 75 shot....also you wont need to remove any timing either.
I have the zex kit and its easy to install and easy to use. You will be fine with a 100 shot.
