Exhaust Experts please help
Old Sep 25, 2008 | 01:57 PM
Tellowman2400's Avatar
Tellowman2400
Default Exhaust Experts please help
So,I have a 96 GT, and I have a prochamber, and Mac cat-back, and it has come around to that time of year when I need to get the car inspected and I live in NJ where they are very strict. So I have a shop that will overlook the visual test but I cant get through the inspection if I am throwing codes, I cleared them but after the car goes into ready mode the codes come back, I don't have the stock midpipe piece anymore, Does anyone have any suggestions on how I can get the car through the private inspection??
I have 2 mills(not installed) but Im not sure if these will even work or whats required
The codes are as follows:
P1035: O2 sensor heater circuit malfunction Bank 1 Sensor 1
P1035: O2 sensor heater circuit malfunction Bank 1 Sensor 2
P1055: O2 sensor heater circuit malfunction Bank 2 Sensor 1
P1055: O2 sensor heater circuit malfunction Bank 2 Sensor 2
Thanks for your help
(on a side note, although only 4 different codes were being thrown, the computer listed them 3 times each for a total for 12 codes, Is this normal?)
Old Sep 25, 2008 | 03:12 PM
jwarner0297's Avatar
jwarner0297
not sure but the mils, wont help cause all 4 sensors are throwing codes. I know a few people that when they put on a new o/r pipe had to change all o2 sensors for them not to throw a code, although this is not typical.
Old Sep 25, 2008 | 03:38 PM
jmmorgan82's Avatar
jmmorgan82
I pulled the bulb from the cluster to get mine inspected. Took 5 minutes and it costs nothing.
Old Sep 25, 2008 | 03:44 PM
Flyingcat's Avatar
Flyingcat
Here in the greater Atlanta area with emissions inspection, the first thing they check is to see if the ck eng lite comes on when the key is turned on...That trick had already been tried, taking the bulb out!
Old Sep 25, 2008 | 03:58 PM
Tellowman2400
well in NJ they hook you up to the computer, so reguardless if their is a bulb your going to throw a code,
I have 2 mill elimanators, will this be enough? why are their and extra two sensors failli ng?
It just doesnt make sence that all 4 would fail, 2 before the cats shoudl be good and the 2 after should be bad, any thoughts??
Old Sep 25, 2008 | 04:06 PM
black35th's Avatar
black35th
Get under there and double check to make sure they are all plugged in.
MIL elims will/should work for the rears, but they WILL NOT for the front. If everything is plugged in then you need to invest in 2 new front sensors and pray that your MIL elims work.
Old Sep 28, 2008 | 05:29 PM
Tellowman2400
so Do I ctually need functioning O2 sensors for the back two if I have MIL's in therE? or will it not throw the rear O2 CEL as long as the Mils are plugged in?
Old Sep 28, 2008 | 08:50 PM
vanquish's Avatar
vanquish
I know someone who would disconnect their battery at the shop for 5-10 minutes. That should keep you CEL off for a while. Your CEL comes back on immediately after reconnecting your battery?
Old Sep 28, 2008 | 09:09 PM
zinc02gt281's Avatar
zinc02gt281
If you are throwing all 4 O2 sensor codes and your front O2's are functioning, you ahve some serious exhaust leak problems coming form the header flanges.
When installing you offroad midpipe, did you buy the gasket for the passenger side header flange?
Pull your O2's out (all 4) and use a multimeter on them to see if they work.
Old Sep 28, 2008 | 11:00 PM
SilvrStang's Avatar
SilvrStang
Not gona work dude because those computers recognize when and how along ago was battery disconnected.
So you're saying they look under the car to see whats up? That sucks bro.
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
Sep 30, 2015 12:39 PM
Sep 24, 2015 09:18 PM
