Threw another code p0340?
Old Oct 4, 2008 | 10:13 PM
2003gtstang's Avatar
2003gtstang
Default Threw another code p0340?
i threw code po340 which is Camshaft Position Sensor 'A' Circuit (Bank 1 or Single Sensor)
. Waht does this mean?? please help
Old Oct 5, 2008 | 12:03 AM
isjoining's Avatar
isjoining
http://www.obd-codes.com/p0340
Old Oct 5, 2008 | 08:16 AM
cliffyk's Avatar
cliffyk
TECH SAVANT
From the '03 shop manual...
Old Oct 5, 2008 | 12:50 PM
allied107's Avatar
allied107
I had this same problem with my mustang. There is a camshaft sensor I replaced it 3 times and the light kept coming on for the same code. I would put the part on clear the code drive around the corner and bam right back on. Come to find out my alternator had something to do with it. Good luck.
Old Oct 5, 2008 | 01:01 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
I had forgotten about that, EMI/RFI from a failing generator can inject noise into the CMP sensor's signal...
Old Oct 5, 2008 | 01:06 PM
blackstallion666's Avatar
blackstallion666
If the code comes back immediatly after clearing it. Try removing the serpantine belt and restarting the car and see if the code comes back. If the code doesn't come back. then your alt. is at fualt. Also DPFE sensors have been known to cuase signal interferance and generate codes as well.
Old Nov 3, 2008 | 11:31 AM
BBZracing's Avatar
BBZracing
Default Been there...
After changing cam sensor twice (and having the code pop up again and again) I did some research and found that the alt could be the problem. After I changed it no issues.
Hope this helps.
Old Nov 3, 2008 | 12:30 PM
Brute03's Avatar
Brute03
yep, had that problem too and after alot a reading and head scratching i found out that the voltage regulator was the problem - a bad diode or something....
BOB ROME
Jul 26, 2023 01:54 PM
mrtrodonet
Sep 19, 2020 03:12 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Dathan
Oct 5, 2015 05:52 AM
ChampInSD
Oct 2, 2015 04:55 AM
