36 lbs Injectors?
36 lbs Injectors?
i have the kenne bell 9psi kit with 36lbs injectors they send with the kit and just curious what are they rated for crank hp wise? im hearing different answers, any input would be great. thanks!!
wow that sucks im already at 407 crank hp and i was plannin on getting the big tube kit which they said would get me over 400rwhp at 10psi!! that wont happen if their only good for 420hp. wonder why they send those out with their kits.
you could look in to a B.A.P. to help out.
if you get your car dynoed then you can check out your a/f ratio to see if you are running out of injector when you add your intake.
http://www.witchhunter.com/injectorcalc1.php4
