Bent my Axel!!!
Old 10-12-2008, 08:23 PM
03GeeTee
03GeeTee's Avatar
Default Bent my Axel!!!
Ok here it goes,
A while back i was playing around on some curves and accidentally slid my driver's side back wheel into a tiny curb (about 1.5 inch) pretty good. When I got out to look at it it didn't seem like it did too much. All I saw was a nice dent in the lip of the rim... Fast forward a few days and I start to notice a squeaking sound coming from the same wheel. Well I pulled the wheel off and looked at the pads and rotor and notice that the outer half of the pad was completely worn down and had made a really erratic wear pattern on the rotor... so i replace the pads and rotor and the next day the squeaking resumes. Me and a few of my buddies proceed to lift up the whole rear and when we spun the wheel we notice a definite wobble even when when we used a different rim... so the only thing I can think of is that my axel somehow bent from hitting this 1.5 inch curb...If this is indeed true I need to know the best (and cheapest) way to correct this so i don't go through a pair of pads per week
BTW: I never felt any change in the handling or anything afterwards even at high speeds
03GeeTee is offline
Old 10-12-2008, 08:31 PM
volcomchester18
volcomchester18's Avatar
you need to buy a new axle. Its not hard to change, pretty easy.
volcomchester18 is offline
Old 10-12-2008, 08:38 PM
03GeeTee
03GeeTee's Avatar
where's the best place to get them? Any specific manufacturers I should look for? Also, how easy would it be to upgrade to a stronger axel?
03GeeTee is offline
Old 10-12-2008, 08:53 PM
StriderTacticaL
StriderTacticaL's Avatar
Probably a good time to get a a new 31 spline diff. with 31 spline axles
StriderTacticaL is offline
Old 10-12-2008, 09:56 PM
dimebag
dimebag's Avatar
just go get a set of strange, moser, or alloy, what ever brand u want, stock splined aftermarket axles, and call it good
dimebag is offline
Old 10-12-2008, 10:01 PM
03GeeTee
03GeeTee's Avatar
Thanks for all the quick responses. Is there any place online that has detailed instructions on exactly how to pull the old axels off and install the new ones?
03GeeTee is offline
Old 10-12-2008, 11:42 PM
ZW99GT
ZW99GT's Avatar
I've got 2 axles out of a 03 GT rear. They have less than 40k miles and are in perfect condition. The only reason I took them out is b/c I upgraded to 31 spline.
The Mosers are around $270 for a pair for replacements. I'll send you one (or both) for way cheap if you are interested. PM me.
ZW99GT is offline
Old 10-13-2008, 12:16 AM
StriderTacticaL
Hey ZW where did you get your prostars? I want a pair for the track visits but I haven't seen them online anywhere
Old 10-13-2008, 12:19 AM
ZW99GT
ZW99GT's Avatar
I traded my old 2003 chrome Cobras for them. They are everywhere. lol. Check out the summit stars on summitracing.com . They look nice and are quite a bit cheaper than the Welds. The welds are on summit also.
ZW99GT is offline
Old 10-13-2008, 12:43 AM
StriderTacticaL
Oh cool lol.. I don't know how I overlooked summitracing.com
Anyway, which prostars am I suppose to get? obviously 5 lug and I also heard that 15X8 is the standard right? I want to be using 275's.
Which backspacing am I suppose to go with? 5.5?
yourmom6990
3.7L V6 Technical Discussions
10-14-2015 10:08 PM
SterlingStunner
5.0L V8 Technical Discussions
09-04-2015 06:28 AM
SterlingStunner
08-27-2015 11:33 AM
dragman72
08-09-2015 12:54 AM
Mustangggg
01-06-2004 12:23 AM
Quick Reply: Bent my Axel!!!
