Chirping noise areound corners
I noticed a few months back that whenever I would back out of a parking spare or something, OCCASIONALLY my car would chirp as I turned the wheel while going slow speeds and backing out. It would only chirp for a second.. but it was embarrassing.
But anyway.. I don't really live in an area where there are a lot of parking garages or places where noises are amplified if you drive in them.. but the other night I was going UP around and around and around SHARP turns in a parking garage and the steering was making chirping noises left and right.. I had 2 chicks in the back and it was very embarrassing because they were asking if my brakes were okay... It's obviously not my brakes but still..
Does my power steering pump have a leak? And if so, what is the best route to go about fixing this? Could it be any other problem? Bent axle? Tie rod or something? Tire?
This chirping really concerns me because it has been happening more frequently lately.. It actually happened today going around just a slight bend at around 30mph too..
THANK YOU GUYS VERY MUCH!! =)
Also, I encountered this squeal again today while going straight, and at a slow speed.. very annoying.
On a 2000 GT could also be the p/s pump. 99-00 ish had noisy P/S pumps to begin with. If the noise happens when the wheel is turned all the way in one direction then it's the P/S pump. The Idler/Tensioner pulley would make noise when the A/C is on as well as it puts similar drag on the belt.
Ford told me that it was most likely a power steering leak back a few months ago when I told them about the problem..
If it's happening only with the car stopped or barely moving check this out...
Have someone* rock the steering wheel back and forth, with the engine running, while you stick your head under the front end and observe the steering rack. On my '03 the rack was moving 1/8" or more in synchronisation with the squeak/chirp.
* - For obvious reasons make sure this is someone you trust, I had my wife do it and have to admit I was still a bit nervous.
