Starting Problem
Old May 23, 2005 | 10:44 PM
98stngfrk's Avatar
98stngfrk
Default Starting Problem
OK so my 98 GT has been haveing a little trouble starting for a little while now. Sometimes when you go to start it, it seems as if you have to hold the key longer than I use to. Also sometimes it will act as if it going to cut off then just run fine. At other times it just starts up perfect. I AM LOST. So I have heard that fords do this, so does anyone know what the problem is and how to fix it? Thanks
Old May 24, 2005 | 01:43 AM
demon_head's Avatar
demon_head
Default RE: Starting Problem
I had a similar problem with my 96 GT. Every now and then it would kinda drag *** on starting, like the engine would turn over a few extra times before it fired up. And then a few times when it did do that, once it did fire up, it kinda sputtered for a second and then was fine. I don't know what it was, but i changed my fuel filter and haven't really had it happen again.
Old May 25, 2005 | 07:34 PM
98stngfrk's Avatar
98stngfrk
Thanks for the reply gave me one more thing to change this weekend, I am changing spark plugs, wires, coil packs, now the fuel filter, if this doesn't work i will guess i will change the starter too. Somethings got to work ya know
djbigskrilla
Sep 20, 2022 01:04 AM
jjwinel78
Aug 17, 2015 03:34 PM
cvarner131
Aug 17, 2015 07:38 AM
KEM Motorworks
Aug 14, 2015 10:13 PM
Pain.
Aug 7, 2015 10:48 PM
