Backfiring?
Old May 24, 2005 | 12:02 AM
sk8erdudex's Avatar
sk8erdudex
Default Backfiring?
Lately I've noticed that when I'm just sitting there and I rev my engine it will backfire once in a great while. Also some brought to my attention that when I floor the pedal in a race I produce lots of black smoke. Any ideas on why this is happening or if the 2 issues are related?
Old May 24, 2005 | 12:40 AM
00GT00's Avatar
00GT00
Default RE: Backfiring?
Black smoke is carbon build up, not good but not bad. If it was white then your in trouble.
Backfire... Might want to try some fuel injector cleaner. Should help with the carbon as well.
Old May 24, 2005 | 12:51 AM
sk8erdudex's Avatar
sk8erdudex
do you think it has anything to do with nitrous or the fact that I use 91 octane
Old May 24, 2005 | 06:44 AM
sk8erdudex's Avatar
sk8erdudex
bump
Old May 24, 2005 | 01:59 PM
neogenic83's Avatar
neogenic83
plugs could be going. check the gaps to make sure they are still in spec .054
Old May 24, 2005 | 08:40 PM
sk8erdudex's Avatar
sk8erdudex
I just changed my plugs and gapped them at 37 to retard the timing
Old May 24, 2005 | 09:27 PM
Dan04COBRA's Avatar
Dan04COBRA
Black smoke = rich.
Old May 24, 2005 | 11:19 PM
sk8erdudex's Avatar
sk8erdudex
What causes it to run rich?
Old May 25, 2005 | 01:02 AM
StickShifty's Avatar
StickShifty
your Mass airflow cencor could be dirty causing it to read wrong and making to car rich. its not good to run rich or lean.
Old May 25, 2005 | 01:03 AM
StickShifty
also my friends supra was running rich because a vaccum line fell off of the engine causing a sensor to read wrong, check the vaccum lines.
Sean
Aug 15, 2004 03:50 PM
Disgustang
Jul 27, 2004 09:43 AM
Obsol3te
Jul 26, 2004 08:42 PM
spuckie
Nov 21, 2003 05:51 PM
tchamber
Nov 9, 2003 05:47 AM
