ENGINE QUESTION
Old Oct 19, 2008 | 04:53 PM
Laneo2007's Avatar
Laneo2007
Default ENGINE QUESTION
Hey everyone I'm new to mustangs, and i might have some obvious questions so bear with me.
what is the difference between a 4.6 and a 5.4? i know that the displacement is different but what differenciates the two? is it the block or the stroke or the bore or a combination of them?
thanks in advance for the info
Old Oct 19, 2008 | 04:58 PM
myslow2002gt's Avatar
myslow2002gt
The 5.4 has a taller deck height and longer stroke. The bore size is identical between the two.
Old Oct 19, 2008 | 05:02 PM
Laneo2007's Avatar
Laneo2007
Default engine ?
what is deck height?
And where could i get a crankshaft to up the stroke jegs? or would it be shorter connecting rods?
Old Oct 19, 2008 | 05:09 PM
myslow2002gt
Deck height is the distance between the crankshaft centerline and the deck surface.
The 5.4L has far more stroke than it needs, these engines you need to concetrate on maximizing the bore.
Old Oct 19, 2008 | 05:16 PM
Laneo2007's Avatar
Laneo2007
so, if i were to get an aluminum block should i get it bored out .020 or .030? would that make a difference in the pistons or just the rings? would the heads/gaskets interfere with the combustion?
Old Oct 19, 2008 | 05:20 PM
myslow2002gt
A .020" 0r .030" over bore will only marginally improve cylinder head airflow, you should look into a big bore (ie. 3.700" bore size).
Headgaskets are not an issue.
BTW, the only aluminum 5.4L block made is the Ford GT and it's priced at over $3000 and requires machine work to fit in a RWD application. Not practical for almost everyone.
Old Oct 19, 2008 | 05:23 PM
Laneo2007's Avatar
Laneo2007
what website could I find one on? jegs, summitt, or something along those lines?
Old Oct 19, 2008 | 05:32 PM
FORD TOUGH's Avatar
FORD TOUGH
4.6 stroke 3.5433
5.4 stroke 4.165
Old Oct 19, 2008 | 05:49 PM
myslow2002gt
You can find blocks on there, but they are overpriced. Locate a local FRPP dealer, and you'll surely find a much cheaper price tag.
GimpyHSHS
Aug 29, 2015 06:30 PM
classic69FB
Aug 12, 2015 11:58 PM
$A_Money$81
Aug 11, 2015 01:30 PM
HIS S-197
Aug 10, 2015 05:47 PM
