head porting
head porting
i found a place near me that only does work with heads and cams. They told me that they would port my heads for 1 thousand bucks. is this resonable, good deal, ripoff? my friend with a GT wants to do the asame. i might go at them with the offer of porting both for 1600, 800 each, is this a good deal for me and will they probably accept it?
RE: head porting
u will gain hp even if ur not at your max flow rate. u got alot of mods done so they will help. porting is something that is real good for when you cam a car, it puts the extra lift of the cam to good use.
RE: head porting
im still sure his heads dont need porting. he has 4 valves. no i could see some use in a 2v head but for 1600 it would not be worth the gains. you could pick up a FR500 intake for that or some bitchin cams.
so explain to me why porting his heads right now would be worth the $2000 or $1600
