Upgrades
Old Oct 26, 2008 | 09:20 PM
96GTSMOKER's Avatar
96GTSMOKER
Default Upgrades
Ok to start I have a 96 gt. I have had the motor built with 2003 5.4 PI Heads, New Intake and 2003 Pistons. 10.5 to 1 compression. I dynoed at 260 hp 290 lbs trq at the wheels. I want to do upgrades. I am thinking of a 100 shot of nitrous. If it won't urt the motor. Also the plenum upgrade to a 75 mm tb and plenum. Cold Air intake and SCT Tuner. Pulleys by steeda. 90 MM MAF. Which or any combo of these should I do. Possibly even a Cross over pipe with no CATS. Any feed back would be helpful.
Old Oct 26, 2008 | 10:33 PM
02 Ninja's Avatar
02 Ninja
I really don't know what to say other than ask, what are 2003 pistons? How about breaking it down a little more. Do you have forged pistons? Explain your built motor starting at the crank and working your way up...............please.
Old Oct 26, 2008 | 10:45 PM
NinetySix GT's Avatar
NinetySix GT
The 100 shot won't hurt the motor, but I highly recommend getting a nitrous dyno tune and the proper safety equipment like WOT/window switches. NX makes a nice plate kit for our GTs. As for all your other bolt on upgrades sound good and I highly recommend LT headers, but you don't need a new MAF just yet.
Old Oct 26, 2008 | 11:46 PM
mustangman281's Avatar
mustangman281
Banned
If your using 03 pistons then you dont have 10.5 compression. You have no need to upgrade your MAF yet.
Old Oct 27, 2008 | 09:03 AM
96GTSMOKER's Avatar
96GTSMOKER
I appreciate the info. They are stock 03 Pistons. I do not want to use headers because they are hard to put on. lol. Every thing else is easy.
Old Oct 27, 2008 | 09:31 AM
1998 GT's Avatar
1998 GT
do gears and tuner
Old Oct 27, 2008 | 11:24 AM
96GTSMOKER's Avatar
96GTSMOKER
I have 4:10 gears already. Do you think a tuner and x pipe methanol with nitrous injection would get me to 380-400 hp.
Old Oct 28, 2008 | 08:24 AM
1998 GT's Avatar
1998 GT
forget what i said earlier then and i see you already have a tuner. probably not but ive seen crazier things happen. you should have gotten those heads ported while you were in the engine and got some bigger cams.
PaulH2
20
Jan 31, 2016 09:48 AM
jrrhd73must
Oct 2, 2015 09:17 PM
Boostaddict
Lethal Performance
Oct 1, 2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
Oct 1, 2015 08:57 AM
UrS4
Sep 30, 2015 10:13 AM
