Right after an oil change
#21
Yea but.. my car's new long block engine has a 3 years warranty on it.. If I put in 6 quarts and something happens.. I'm screwed.. because that's not what the book says.. lol
Can't you create a frothy oil by overfilling it? The connecting rod starts getting oiled if you put that much in..
#22
Yeah, Heaven forbid the connecting rod should "start getting oiled" (what does that mean?)...
I have had several sources (here and through other postings and PMs) verify that the oil pans are the same across all 4.6L engines, to the extent that I buy it--and that Ford's reduced fill recommendation for '98 through '01 was based on bad information. And that they corrected that in '02.
Feel free to do whatever you want. I would run 6 qts in that engine unless you drive like my mother-in-law (she's 88)...
#23
Well, the connecting rods I meant like.. obviously if you over-fill the oil pan you can froth your oil.. the connecting rods will whip the oil like mayonaise.
I think I will go with 5 Quarts because I take the car to about 3k maximum. In 3,000 miles worth of having my new engine.. I have only brought the car up to 5k once. (4k a couple times)
#24
In any event running 5.0 qts won't hurt anything as long as you're not even close to pushing it. Musta' been scary at 5k
#25
You're referring to Windage.
The amount of Oil you use does affect windage (Correct vs. Not correct). You can counteract this by adding the correct amount of oil.. Or a windage tray if you're really, really ****.
#26
Actually it is called aeration, with windage being one of the causes. There are several other ways to induce oil aeration in an engine outside of the crank and connecting rods whipping through the oil. Ford corrected this problem with various other developments, which I'll allow the posters to figure out.
#27
#29
#30
Mine car takes 5 quarts. 6 overfills it. But, from the discussion on this thread, it sounds like the only difference in oil capacity between the 99-01 and the 02-04 may be the marks on the dip stick.
I run 5 quarts (what the manual says) and I run my motor to redline all the time. There is no sign of any problems. There are also a lot of high mileage 99-01's around so why is overfilling the oil a good thing?
