Engine is IN!
Engine is IN!
So last night i finished up everything with my rebuild except the wire harness.. ill tackle that today after school. But few things before it is completed fullly
1st : I did a egr delete because pypes headers dont have the part to connect the egr pipe to the port on the header. So i am just going to delete that.. Does anyone know of where i can get a delete kit? I found the block off plate but dont know where to get a cap for the port on the header??
2nd : I just want everyone to know that buying pypes long tube headers is a bad idea.. I bought their headers and mid pype. The headers contact the transmission on the passenger side (which really isnt a big deal) also the stater motor has to be shaved to fit in with the headsrs. AND! the mid pipe i bought from pypes that is suppose to line up with the headers didnt!!! I swear they were drunk when they produced these or something. Also when i tried calling them about the egr problem they were no help. They told me that there was suppose to be a male thread part to connect the egr to but then they said oh nope we dont supply that you just have to get this block off plate (they only showed me the plate and not the cap for the header).. and something that i am worried about is the O2 sensors are pointing down on the mid pipe and i can see them getting ripped off by a bump or something
Ya kno i just thought about it i need something different then just a cap because i dont have that thread to screw on the cap on these headers. I would need like a bolt to screw into the port. These headers are so ****ed! wtf
i ran into similar problems but you can just take out the male/female connector off your stock manifolds and screw it into the pypes headers. The midpipe is a PITA to get on but you should be able to stretch it on. I had a BBK x and i was able to pull it over so i could bolt it up. As for the starter that is the only thing that really pissed me off. I ended up just sucking the starter on with the bolts which just put a small dent in the header. that doesn't bother me though.
Does anyone know if it would be okay to turn my car on with out the egr port on the header being blocked off. I really wanna hear what it sounds like-ish haha
also would deleting this throw my check engine light on? i thought i saw somewhere that it will and i have to get it tuner to turn it off
I wouldn't say i'm pissed off with the product but it is kind of annoying that you have to put a dent in new headers, in order to get the starter back in (or grinding like you did). I think they are good headers but just think about it, you will have problems with every header install out there that makes you want to burn down the company who made them. they are worth it though.
I wouldn't start it without it capped cause you will get a nasty exhaust leak i would guess and it will sound like garbage, not even close to what it will sound like with it capped. as for the CEL i'm not too sure but i would guess you will get one.
Really i am happy with the headers, the stainless steel is why i got them. Now that they are in and all im over it. It was just a bitch putting them in. How did you install your headers? I was putting my engine in at the same time which KINDA made it easier ha
i was also putting my engine in but i could not drop it in with the headers on because it kept hitting the transmission then i could get it by that then it would bind up on the k member. I only had the passenger side one on though since the driver side has to have the steering shaft through it. So i ended up pulling the motor back out taking the header off and dropping the motor back in. then pulled the k member and had the headers on in about 2 hours with no help.
AmericanMuscle4.6GT
11-10-2015 02:06 PM
TfcCDR
09-14-2015 12:08 PM
