Intake cracked. Hydrolock
Old 11-06-2008, 03:47 PM
pinto18
pinto18's Avatar
Default Intake cracked. Hydrolock
It FINALLY happened to me. Two days ago my intake cracked so i tried driving it home. I was about 3 blocks away when out of nowhere it just died. I tried starting it back up but nothing. I saw fluid coming out of my exhaust so i was scared it might have gotten hydrolocked somehow. Is this possible?? I havent done anything else to it and its just sitting now. I tried searching for answers but none mention hydrolock.
pinto18 is offline
Old 11-06-2008, 03:49 PM
99BlackPonyGT
aka 'Negative Nancy'
99BlackPonyGT's Avatar
hydrolock and it wouldnt even turn over...and i dont even see how hydrolock would be possible unless you blew out a spark plug at the same time or something lol...
99BlackPonyGT is offline
Old 11-06-2008, 03:57 PM
pinto18
pinto18's Avatar
Phew!! That gets a load off my shoulders lol.. But any ideas of why it wouldn't turn on after that then??
pinto18 is offline
Old 11-06-2008, 04:15 PM
35thAnni99GT
35thAnni99GT's Avatar
Location: Where gunshots are more common than birds chirping
Cracked intake would let in too much air after the MAF making it too lean and hard to start probably. If you hydrolocked, it would be exactly like it sounds. Your motor would lock up completely.
35thAnni99GT is offline
Old 11-06-2008, 04:19 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
If the intake cracked in a manner that allowed coolant to get into the lower plenum then it is likely the plugs are fouled with coolant.
Do NOT continue to try to start the engine. Anti-freeze is a horrible lubricant for metals and you can damage the rings by turning it over;
Also, do NOT wait too long to get the problem fixed. Engine coolant is 1/2 water and it can create all sorts of corrosion and other problems in the cylinders;
Do get a new intake manifold, new spark plugs, and change the oil (and filter) before starting the engine--I would also change to oil and filter again after 100 to 200 miles, but I'm **** about stuff like that;
cliffyk is offline
Old 11-06-2008, 04:23 PM
pinto18
pinto18's Avatar
Oh i c. Yea sounds like i should b safe then. Im glad i ONLY have to replace the Manifold. Thx 4 the help
pinto18 is offline
Old 11-06-2008, 04:28 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
Don't let it sit, you need to do this within 3 to 5 days, a week tops...
Oh and then after getting the engine hot take it out a drive on the highway for 15 to 20 miles to bake out the remaining crap. You can do the followup oil change after this...
cliffyk is offline
Old 11-06-2008, 04:32 PM
pinto18
pinto18's Avatar
I dont have the manifold in yet. I dont wanna get started with it yet because i wont remember where it all goes after. What can i do for now??
pinto18 is offline
Old 11-06-2008, 04:41 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
You could do nothing if you are going to get to it in a couple days, or if you want to do something proactive you could pull the plugs and put an ounce or so of engine oil in each cylinder, then pull the fuel pump fuse (fuse 14 in the under hood box) and turn it over for 4 or 5 seconds.
There shouldn't be much oil spray, but I've never done this on a 4.6L mustang--you may want to put some old towels or something over the plugs holes just in case.
Put the new plugs in, and make sure you torque them properly...
cliffyk is offline
Old 11-06-2008, 05:00 PM
pinto18
pinto18's Avatar
Good point i was going to replace the spark plugs anyway. Ill get right to it thanx. One more thing i remember something about spark plugs blowing out if you dont install properly. Do You happen to remember what cylinder that was just as a precaution or if its all cylinders??
pinto18 is offline
Quick Reply: Intake cracked. Hydrolock
