which one to get...
It seems that i have the worst luck in the world. If i get one thing figured out,sumthin else happens. Right now my question is where should i get my lower intake from,what brand,etc. And also is there nething else i should look into replacein while i have that off? I need a new lower intake manifold,because my old one is cracked and the holes are stripped out where the previous owner had messed with it i guess. Also what kind of gains am i gonna see? And is there ne write up on how to change em out,like what needs to come off,etc. thnx
Pretty straight forward swap. If you got the money get the Trick Flow Track Heat, but otherwise stick with the stock PI w/ aluminum crossover. You won't see great gains with the trickflow without supporting mods. I would ask for your mods, but i left my pinkslip in my car.
You're gonna get many different replies. I personally have the Typhoon from PP. Some like it, and some don't. Trick Flow makes a good lower intake and if you have the HP to play, Fox Lakes P-51 is nice. Eventually, BBK will quit pulling our nuts and release their intake.
i was thinkin about gettin the typhoon off ebay for like $550...but im tryna see what everyone says...
the mods are....k&n filter,c&l intake tube,c&l maf,bbk throttle body,professional products plenum,grantelli coils,steeda timing adjuster,u/d pulleys,bbk headers,o/r x-pipe,slp exhaust,and sum more i cant think of everything right now,and sum suspension.
