At what point do you need 1 degree colder plugs?
Old Nov 13, 2008 | 10:01 AM
tws1098's Avatar
tws1098
Default At what point do you need 1 degree colder plugs?
Is it any time you go FI or is it a power level thing?
Old Nov 13, 2008 | 10:13 AM
mustang_pa's Avatar
mustang_pa
I would say yes, you do need to go a colder plug at any time you go blower/turbo/nitrous as i have always done. A colder plug removes heat faster than a warmer plug. I don't know about cams cuz i haven't gotten to do that yet. A heat range of 5 is good for a blower install on a street stang. I would assume if someone was only making 250whp they still have stock or equal to stock plugs and only some bolt ons. Maybe if you got to 300whp N/A you would think about the colder plugs cuz you either have cams or some nitrous and bolt ons, 400whp+ you would most likely have some kind of F/I and would need a colder plug. That is just my thoughts by no means am i am expert. So maybe someone else can answer this ? better.
Old Nov 13, 2008 | 10:20 AM
tws1098's Avatar
tws1098
alright, that pretty much falls in line with what i was thinking. Thanks for the thoughts.
Old Nov 13, 2008 | 03:04 PM
dennis_112's Avatar
dennis_112
NGK TR6's are a perfect blower/nitrous plug.
Old Nov 13, 2008 | 04:13 PM
Obsequious1's Avatar
Obsequious1
I've been running platinum plugs for over a year and I haven't had a problem. A cooler spark plug sparks at a lower temp. When you have a blower you need to run a higher octane fuel which burns slower because your compressing more air which leads to more heat. Just like diesels, all that psi makes so much heat it doesn't need plugs and diesel burns slow.
Thats my 2 cents.
Old Nov 13, 2008 | 04:17 PM
Obsequious1
Oh yea, If your running like 13 or 14.1 compression ratio then you probably would need a cooler spark plug too
Old Nov 13, 2008 | 04:23 PM
vortech01vert's Avatar
vortech01vert
when would you need to run two steps colder? trying to decide on what i need
Old Nov 13, 2008 | 07:32 PM
RuffCat's Avatar
RuffCat
BR7's...??? Only if your over 12lbs of boost is a good figure
Old Nov 13, 2008 | 09:14 PM
waggs's Avatar
waggs
not to jack the thread but is there a such thing as too cold of a plug? like if you're n/a and running a plug two steps colder than stock?
Old Nov 13, 2008 | 11:13 PM
jbors1's Avatar
jbors1
no but it wont do you any good.
BOB ROME
Jul 26, 2023 01:54 PM
jwog666
Dec 27, 2021 08:09 PM
Dathan
Oct 5, 2015 05:52 AM
Sep 25, 2015 09:06 AM
SteelerNation82
Sep 16, 2015 07:11 AM
