P0340 code
Old Nov 23, 2008 | 07:39 PM
jheaj's Avatar
jheaj
Post P0340 code
I got the camshaft positioning sensor code to come up a while ago and i went ahead and replaced the camshaft sensor. It came back on the next day so i went ahead and replaced the crankshaft positioning sensor to be on the safe side. It is still shooting out the code after resetting them both times. I am out of ideas and it is hard to crank the engine and i noticed i am using more fuel than before. I have heard that it might be the alternator diodes causing this. Any other ideas?
Old Nov 23, 2008 | 11:08 PM
Brute03's Avatar
Brute03
it's more than likely your alternator, specifically the voltage regulator. i had the same prob a while back and it was hell to find
Old Nov 24, 2008 | 09:40 AM
BBZracing's Avatar
BBZracing
Default Agree...
Had the same issue...after replacing 2 cam sensors I did some research and found info on the alt possibly causing the code. Changed alt and prob solved.
Good luck.
Old Nov 24, 2008 | 10:36 PM
jheaj's Avatar
jheaj
Thank you guys for the help. I am going to change the alternator and hope it solves my problem.
BOB ROME
Jul 26, 2023 01:54 PM
mrtrodonet
Sep 19, 2020 03:12 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Dathan
Oct 5, 2015 05:52 AM
ChampInSD
Oct 2, 2015 04:55 AM
