Camshaft stage 2 or 3 ?
hello everyone Iam new here .. I have 2001 GT with bolt on ( pulleys , intake , LT with x-pipe and 3.55 gears .
and iam planning to go with camshaft stage 2 or 3 ..
iam asking what is the better for my daily use with stock heads ..
Iam going to change my valve springs and cam-gears and bolt-on cam gears kit and the retainers ..
I want power and my engine life
the stage 2 comp cam
550 lift
in- 270°
ex- 274°
the stage 3 comp cam
550 lift
in- 278°
ex- 282°
which one can i take for my daily use without replacing my heads
plz any one help me ... and sorry for my bad English
550 lift
in- 270°
ex- 274°
550 lift
in- 278°
ex- 282°
If you are going to be running on a stock short block, there is no need to run stage 3 cams. The power range is set much higher then you are going to want to spin the engine.
A stage 2 cam should be all you need for a bolt on/cam car. Depend on the cams you get, it shouldn't be too bad to drive it daily.
Edit: There is something wrong with the specs you listed, I'll admit I'm not too familiar with comp cams but those numbers seem way to high.
Check these cams out, they are local guys to me and they have been getting great reviews in the cam world lately.
http://www.hitechmotorsport.com/inde...pper&Itemid=85
The stage 2's are good for both N/A and S/C? I've read most N/A cams make it harder to build boost. I was looking for cams I could get that would give me some decent gains now without hurting me later when I supercharge. I saw a lot of people on other forums running blower cams on their N/A car, but it didn't make much sense to me.
I think it's the LSA that makes the difference in a N/A or S/C cam...a S/C cam usually has about 112-114 vs about 110-112 for a N/A cam...also a S/C cam has high lift and long duration on the exhaust side than a N/A cam...stage 2 and 3 comp cams are probably better for a S/C engine but the stage 2 is also pretty gor for a N/A if that makes any sense...
If you know your going to go s/c in the future I really wouldn't waste your time with any NA cam, even if it does "ok" with a s/c application. I would just buy cams that are meant for the application you plan on running.
I have the comp stg 2's w/nitrous and they are great. Deathrattle is correct n/a or s/c has more to do with the LSA.
Defintely wouldn't go stg 3's if is your DD and if you do you'll need 4:10's at the minium
