Hissing noise while cold
My car seems to make a hissing noise, randomly, until its warmed up. Im not sure whats causing it but it hisses, then stops for a while then hisses some more then stops and keeps doing this until its warmed up.. My AC is off while it does this and its a pretty quiet hiss, it just sounds wierd and i dont know if its normal, anyone have any ideas?
it was louder for me today... no clue why it is happening but it sounds like an air leak
it seemed to happen only under load, accellerating normal in 1st gear u could hear it well, 2nd also but just revving it in neutral didnt make the noise
is this normal? it sounds like a leak but it goes away when the car is warmed up
Today I noticed it only does it after I let the clutch out.. sounds like air leaking for a few secs after sometimes any ideas?
edit - it happens when just sitting there when i start it up now too
Last edited by Andy13186; Dec 13, 2008 at 12:40 AM. Reason: started happening when in neutral
The hissing noise is -probably- your IAC. I really noticed that mine became much more pronounced, especially in the cold after I did the IAC restrictor mod. If this is the case, it's no big deal... just the noise of the air moving through it.
it sounds like its coming from under the car or low in the engine bay, toward the back of the engine
KingRando
Oct 2, 2015 08:06 AM
