700 RPM idle ????
700 RPM idle ????
My car seems to drop to 700 RPM after the car has warmed up. When I'm behind the car and listen to the exhaust and it seems to sputter every few seconds.
Also, when I'm driving and get on the gas, it seems to hesitate/sputter a little before it goes. Just changed the spark plugs to TR6 gapped at .040
What could be the problems. If its the IAC, where is that located on the 97 cobra, OR if its a vacuum leak, where do I check???
The car has not been tuned or chipped.
Need help
Need help
The TR6 is what was recommended for the 96-98 cobra from what I read in the post and what a local mustang shop said. It had a slight tick before I changed the plugs anyway.
Just curious why after the car warms up, the rpms drop to 700 and the car begins to sputter/misfire. The car is very strong but hesitates a little when I punch the gas while driving. Don't understand why
It's gotta be MAF or vacume leak sinse you changed the plugs. Just take you rhand along the tubes to find vacume leak, with maf, i would just go to autozone, ask for one, ask if you can return if you bought the wrong part, puot it on, if it's not maf return it Autozone is good about returns where im from, but may wanna make sure u can return it so u dont waste money.
Im betting it was. I suggest you pull all your plugs and make sure none have backedout already. Check the threads on the plugs for any metal from the heads. The tick you hear could be the sparkplug backing or backed out. If you tightened the plugs TOO much you could have stripped out the threads.(Theres only 4) my car backed out a plug and it took me like 8 hours to fix it... and a WHOLE lot of ingenuity lol i heard heli coils like to backout so i made my own out of a Sav-a_thread kit with inserts and i dremeled one out to make a Seat for the sparkplugs. Your car has tapered sparkplug holes. Goodluck and i hope it wasn't the plug blowing out that was a real PITA.
When I changed the spark plugs, every single one went in fine, no problems with over stripping. I tightened all at the recommended torque. I'm not sure what the MAF would have to do with it. What about the IAC, where is that at on the 97 cobra or does it even have one???
I'm guessing that the low idle and engine sputter has something to do with the cars ticking. I swear the ticking is coming from the middle fuel injector on the drivers side. I put the screwdriver right up to it and listen with my ear. I can hear it ticking, man this is driving me nuts. Just want my car to run well. I just bought the dam thing 2 weeks ago. It only has 38K miles and only 20k on the new motor. The motor was replaced under warranty due to a bad engine knock. I have the paperwork to prove it.
Can't figure this dam low idle and engine miss
