Idle all messed up!!
I am done installing my Plenum and 75mm TB, Now the idle is wierd.. It doesnt revv down as smoothley and it likes to stick at 1500 rpms and eventually drop to 900 rpm(before it was about 600).. Its annoying in traffic because as soon as you put it in first to move up and stop again its stays at 1500 and wont drop and I feel like an idiot when I stop and my angine is going VRRRRRRRRRRR. Is there some adjustment to be made?? Or is that how its gonna mostly be?
RE: Idle all messed up!!
Only a programmer or custom tune can really adjust your idle, but your's shouldn't be doing that.
Try unhooking the battery for a half hour and then driving it again. If that doesn't reset the computer and fix it, you probably have something unhooked or it's air leaking somewhere.
ORIGINAL: Black03
You think the TPS is making all this happen? Aslo when I start the car the rpms shoot up to about 2500.. WTF??
There is a control that may need to be adjusted. It is on the T/B, a small screw that sets the T/B at idle.
Sounds like you didn't get something set correctly on the TPS, or perhaps the car is holding the throttle slightly open at idle. Try adjusting the screw.
I had no problems what so ever with my t/b and plenum when I installed em.
unplug your battery for 2 hours. this ussually fixed all my problems with all my cars. i think it resets the computer im not sure on stangs but on german cars it would reset and they would relearn everything and adjust to the new modifications
