Professional Products tb???
i'm a little concerned about the size of the new BBK piece, 78mm is huge. On the bench test, most throttle bodies lost airflow after 70, the accufab and C&L being the only exception. The accufab flowed exactly the same regardless of size and the C&L favored the 75mm. From what i saw, 99% of the time, any throttle body over 70mm got a power loss...that being said, i went with the 75mm personally, but i had an accufab plenum. now a 78mm, i'm not too sure about that. I like the way it looks but i don't think i'll recomend it to anyone untill BBK or some other person does a flow test on it to see how well it flows.
Proffessional Porducts T/B and plenum is a really nice setup. I run it on my car and I love it. I havent had a single problem with it and few of my buddys run it on their GTs. UPR sells excellent parts.
I have a PP t/b and plenum, no issues easy install. I just used a pair of pliers and press the pin in. I had a slight sticking issue but I removed the black plastic piece in the spring and it pretty much went away.
I have the PP TB and plenum as well, slight stickyness at idle at first, year later it gone now, and yeah i had to open the hole up a bit with a drill for the throttle cable too, still a good price for both, friend has accufab version and inside they look the same
oh here is a website about it, it's mostly about the intake, but they did dyno with the PP TB an dplentum before the intake http://www.mustang50magazine.com/tec...old/index.html
I bumped into a 2003 Cobra owner a couple of months back..........he said his Dad ahs been building Ford engines for decades and has always said that the only reliable thorttle body was a Ford throttle body.........including of course, Ford Racing. Said to me his Dad has found that all other aftermarket ones can have problems sticking.
When I get around to it, I'll pay a bit extra and get a 70mm Ford Racing throttle body.
