Installed the subframes...
#21
Lynn
#26
What $600.00??????? I would most def call the BBB because they ripped you off big time!!!!!!!!!!! I was there when the guy did everything and it took less than 2 hrs. Man that sh** really pisses me off when people take advantage of other people!
#29
A couple of hours labor is all it will take,$600 is way out of line.Maybe they just flat didn't know what you were talking about.A GOOD reason to use another shop.
The biggest thing is to make sure the car is square all the way around before the welding begins.
The way mine was done was to drive the front end onto ramps and lift the rear to match.Use jackstands under both sides of the axle housing to equally load the frame.
I used the Steeda SFC's just because of less welding needed.
