Performance Increased? (PI)?
Old Dec 7, 2008 | 04:47 PM
MustangWill's Avatar
MustangWill
Default Performance Increased? (PI)? Now with additional questions about intake...
I know it's a dumb quest, but I've searched all over the place and the engine either gives me a bunch of unneeded results or it says that my term is used too often or is too short.
How would I know if my mustang has a PI motor? I have a 99 GT and I need a new intake. I know for a fact that the intake I bought is PI.
Thanks for helping out
Old Dec 7, 2008 | 04:56 PM
72MachOne99GT's Avatar
72MachOne99GT
2010 Blue Ball Award Recipient
If it has the original motor, it's a PI motor.
Old Dec 7, 2008 | 07:49 PM
My1stGT's Avatar
My1stGT
i have a dumb question so you will be off the hook but what exactly is PI and NPI?
Old Dec 7, 2008 | 07:57 PM
72MachOne99GT
Performance Improved
In '99 Ford redesigned the heads and intake manifold, and changed the cams a bit. Upped horsepower from 215-225 up to 260.
Quarter mile times dropped almost a full second according to some sources.
Both of you guys have PI cars obviously since they became equipment starting on the '99 Mustang. Some of the F-150's/Grand Marquis/Crown Vics/Explorers didn't get them until later.
Old Dec 7, 2008 | 08:05 PM
My1stGT's Avatar
My1stGT
thanks 72mach ,guess if i dont ask ill never know
Old Dec 7, 2008 | 08:21 PM
72MachOne99GT
yea, that's only a very 'simplified' version..
Old Dec 8, 2008 | 12:06 AM
sufferer's Avatar
sufferer
I didn't know that either so don't feel bad. I learn a lot from this board.
Old Dec 8, 2008 | 03:06 AM
ezking's Avatar
ezking
In 99 they changed over to the PI engines in the mustangs.
Intake manifold was vastly improved, with higher flow and almost dbl the runner length
The cams were vastly improved
The pistons had a changed shape, to go with the reshaped cylinders on the new heads.
The heads were vastly improved, with longer intake runners, larger exhaust ports, different shaped intake ports, different shaped cylinders, and bigger valves.
Mustang HP went from 215 to 260 stock
I've seen PI engines on 99+ mustangs, Crown vics, and I believe I've heard of them in explorers as well.
Old Dec 8, 2008 | 03:53 AM
MustangWill
Thanks for the info. I guess I won't have to worry about any other hardware for the new intake outside of gaskets and possibly replacing the thermostat. It was hard to find info about PI and NPI on the internet because I just kept getting aftermarket parts and stuff.
Thanks for clearing it all up, 72MachOne99GT.
Old Dec 8, 2008 | 12:58 PM
lizzyfan's Avatar
lizzyfan
Underboss
With the exception of the crossover which still was plastic (prone to breaking) until the aluminum crossover was added '01
