oil pump for procharged 4.6
i was jsut wondering if i should run a melling high volume oil pump for my procharged 2 valave build...now should i run the regular melling oil pump or dish out the extra cash for the cobra high volume one...ill be running 12lbs of boost to start, after that ill upgrade my tranny and do a complete fuel system overhaul so i can boost higher...i dont plan on running any higher then 20lbs eventually...any suggestions???
Are you supercharged yet?
Are you running stock rotating assembly?
What is your HP goal?
What stage of the build are you at?
He has a built block, ported heads, 2.5 cms blower cams, plenty of fuel for the power he wants right now.
I know because I am building his car for him.
Doug I can't believe you don't trust me when I told you to just get the $50 cobra pump.
Ehh, Dont blame him, He just checkin around... Good to do some research, maybee a new pump came out you didnt know about and someone else did.
10-09-2015 03:27 PM
