Throttle Pos Sensor
Old Dec 14, 2008 | 11:55 AM
SteveMasterZerox9's Avatar
SteveMasterZerox9
Default Throttle Pos Sensor
Im throwing a code of p0122 thr pos s a cir lo in. after installing a 70 mm accufab throttle body. Could my throttle pos sensor been damaged in transferring it to the new TB or could the screw be set wrong on the new TB which I never touched. Any Help is appreciated.
Old Dec 14, 2008 | 01:06 PM
ezking's Avatar
ezking
When you install a t/b n plenum the tps gets all ****ered up, and it usually takes a couple weeks for the car to adjust and get rid of the hanging RPM's. Update your tune, and it should solve your problem. At least thats where I would start, otherwise I'd be willing to bet if you drive it long enough it will fix itself if you never touched the TPS, might clean it to be on the extra safe side.
Old Dec 14, 2008 | 09:26 PM
Modular_Madness96's Avatar
Modular_Madness96
have you checked the voltage?Id start there.
Old Dec 14, 2008 | 10:19 PM
SteveMasterZerox9
so if the voltage isnt there or not enough then I would assume it somehow broke when removing it and putting it on the new TB??
Old Dec 15, 2008 | 11:23 AM
cobra dreamer's Avatar
cobra dreamer
had the same issue when i did my tb just a few minutes ago i replaced the tps and it is fine no more codes or CEL replace it and you will be fine there only like 50 bucks
Old Dec 15, 2008 | 11:43 PM
Pohatu18's Avatar
Pohatu18
same happened to me when i replaced my TB had to go buy a new tps and still got codes(i bought a broke on apparently). traded for another new one worked fine.
Old Dec 17, 2008 | 05:29 PM
SteveMasterZerox9
Would you guys trust a place like autozone to buy em from or should you purchase it from a dealership. I live right by the biggest mustang dealership in the midwest which i go to all the time but they are more expensive.
Old Dec 17, 2008 | 09:39 PM
cobra dreamer
i got my from the dealer on electronic stuff like that i would only get from the deal
or someone who can get factory parts
Old Dec 31, 2008 | 05:00 PM
SteveMasterZerox9
Finally put on a new tps and got rid of that engine light! Thnx for the help.
jwog666
Dec 27, 2021 08:09 PM
mrtrodonet
Sep 19, 2020 03:12 PM
Dathan
Oct 5, 2015 05:52 AM
UrS4
Oct 3, 2015 06:23 AM
guitarman376
Sep 30, 2015 05:54 PM
