Oil Pressure.. HELP PLS!
Heres how to test it...
Measure the resistances between instrument cluster C251 Pin 16, Circuit 31 (WH/RD), harness side and oil pressure switch C138, Circuit 31 (WH/RD), harness side; and between instrument cluster C251 Pin 16, Circuit 31 (WH/RD), harness side and ground.
No REPAIR the circuit. CLEAR the DTCs. REPEAT the self-test
- Is the resistance less than 5 ohms between the instrument cluster and the oil pressure switch, and greater than 10,000 ohms between the instrument cluster and ground?
