I used RP. My only question is where did it go? We filled it at the fill plug on the side of the tranny and I was getting really worried when he was pumping the 4th bottle in and nothing was coming out yet. I know it's not supposed to hold that much, so where the hell did 2 quarts go?
i dont believe your suppose to use synthetic in the tr3650 and will actually make it more apt to grind. synchros are designed differently and some are designed to work with synthet and some aren't. you said he used a machine to fill it. did you fill the machine up and then pump it in or does it use a big tank (maybe the machine is calibrated wrong).
