How much HP is this engine!
Old 01-04-2009, 07:12 AM
99 Stang
99 Stang's Avatar
Default How much HP is this engine!
Hey Guys i am new to this forum and i am new to mustangs, i have a 99 4.6 and it has a aluminum block with 10 and half to 1 compression and ported and polished heads, and polished manifold, headers and flow master exhaust,and running a 373 gear pos.Quick throw shifter, Would anybody know about how much HP this motor would have, and what parts could be added to raise the HP THANKS!
99 Stang is offline
Old 01-04-2009, 07:49 AM
SnakEater
SnakEater's Avatar
300 tops... u needs a supercharger... turbo.... NOS... one of those...
SnakEater is offline
Old 01-04-2009, 08:32 AM
boduke0220
boduke0220's Avatar
cams and headers would help..or nitrous or ( NOS is a brand) a supercharger or turbo
boduke0220 is offline
Old 01-04-2009, 09:04 AM
POISND U
POISND U's Avatar
If it has P&P heads I pray the previous owner was smart enough to do cams too.....
Didn't you get any info from him when you bought the car?
POISND U is offline
Old 01-04-2009, 09:12 AM
98redstang
98redstang's Avatar
i make close to 300 to the wheels except i have cams, injectors and im dyno tuned... My dyno numbers on my sig are with a 5% power loss to the wheels because apparently my breaks were dragging on the dyno and its only an 87 conservative tune. As for parts to be added i would say cams? Why would someone do all that work pulling the heads off and porting and polishing them and not putting cams in? Are you absolutly sure its even p&p? Anyways after cams i would go with a good tb and some bigger injectors... Or Just get a bigger tb and get a supercharger just be careful with your compression with a supercharger... I would watch out if you spray it with that compression too...
98redstang is offline
Old 01-04-2009, 11:25 AM
Stevecooper
Stevecooper's Avatar
Ported manifold? I assume this is an aftermarket manifold.
Stevecooper is offline
Old 01-04-2009, 12:01 PM
98redstang
98redstang's Avatar
polished manifold not ported it just the finsh...
Old 01-04-2009, 01:22 PM
SeanAndKate
SeanAndKate's Avatar
hmm...you buy from a dealer or a owner? if an owner i bet they got it dyno tuned... if so just ask them. if a dealer you could be out of luck as far as getting good numbers or to much more info about the work done to it. and we will need more info about whats been done to give you a good number if you cant get that info your best bet might be to go to a performance shop and ask them whats going on under the hood.
SeanAndKate is offline
Old 01-04-2009, 03:36 PM
98redstang
98redstang's Avatar
I wouldnt bet on a dyno tune after the op said he doesnt have cams... Maybe it does have cams idk theres just not enough info on this op...
Old 01-05-2009, 08:33 AM
99 Stang
99 Stang's Avatar
I do know it is P&P heads and the manifold is polished on the inside and it is a afther market, brand name tyfune cost $1800.The guy didnt know much about it he just had it about a month......A far as the cams go they sound stock I am going to change them does anyone know what would a good cam for this set up?The pistons are flat top no valve reliefs.I would like to run a turbo but is it to much compression?I didnt really didnt want to do nitirous, I want bolt on power. If i change injectors what kind should i use?
99 Stang is offline
Quick Reply: How much HP is this engine!
