clutch noise PLEASE HELP
well tonight my car starting making this noise its only done it a couple times or at least ive only noticed it a couple times when i push the clutch in it makes the fairly high pitched squelling noise i have no idea what it could be i drove all around tonight it drove fine just like it always does but it made that noise a couple time or at least i noticed it a couple times probably did it more but i had the radio up and my car isnt the quietest the car only has 34k on it and the clutch hasnt been replaced so i hope its not that well im wondering what it could be please help me
RE: clutch noise PLEASE HELP
Adjust the cable by putting the side of your left foot on the side of the clutch pedal and pressing it down a little and pulling it as far up as it will go. Do this several times when the squeel happend and it will go away. You may need a new clutch in the next 10-15000 miles.
What it is is the quadrant is rubblin underneath when the cable gets loose. It happened in my GT a few times also.
i had that same exact problem it started out doing that quitlely then the more i drove and one day it made a extremely high pitched noise which was my throwout bearing when they pulled it out to put my new clutch kit in my throwout bearing was split in half
KingRando
10-02-2015 08:06 AM
junior04
09-28-2015 10:53 AM
